Re: Farmall H - electrical problem HELP!
Posted by Wayne Swenson on April 11, 2004 at 20:39:27 from (66.228.234.63):
In Reply to: Farmall H - electrical problem HELP! posted by Jon Older on April 11, 2004 at 15:36:18:
Most likely one of the diodes INSIDE the alternator are damaged causing the battery to run down.
Any competent electrical shop can replace them; you can do it yourself if you have basic skills.
You need an ohm-meter to test the diodes.
The common Delco S-10 has 6 diodes (3+, 3-) and a diode trio internaly.
Of course, you could buy a replacement alternator, but that takes all the fun out of "doing it yourself".
Good Luck
Post a Followup
: Re: Re: Farmall H - electrical problem HELP!
