Re: mice again
Posted by big fred on April 12, 2004 at 09:34:34 from (130.76.32.15):
In Reply to: mice again posted by farmallsc(NH) on April 11, 2004 at 16:43:07:
You can probably get the bulk of it out by using a shop-vac thru the throwout bearing grease zerk access hole in the bottom of the torque tube. I did that combined with blasts of air pressure. Air pressure to loosen it up, vacuum to suck it out. Biggest problem it will cause is all that stuff will fall in your face when you grease the throwout bearing. Not a problem if you never grease it.
Post a Followup
: Re: Re: mice again
