Re: Block and head milling
Posted by Kent on April 12, 2004 at 19:30:33 from (12.214.34.211):
In Reply to: Block and head milling posted by Kent on April 11, 2004 at 19:54:49:
Thanks for the ideas men, that was what I was looking for. I want to keep it as simple as possible but I thought about finding the D-239? diesel when I found out a crank for the C-200 was $525 to $600. I was able to get mine reground to 20 under on the mains and 40 on the rods. The poor thing had STD bearings and I would guess it was ran out of oil after I spotted the brazing on the oil pan.
Hugh, I hope all is well with you and your family. I have not been working on the 2544 much due to just starting on the new house. I did get it out of gear(3-gears at the same time) and cleaned out the tranny/rear/hydraulics. I am going to try and get someone to weld on the manifold and have it resurfaced. The only ones I have seen look like they have the exhaust outlet in the wrong spot. Any way thanks for the help. Kent
Post a Followup
: Re: Re: Block and head milling
