544 D fuel tank problem
Posted by Tim (ny) on April 12, 2004 at 21:08:04 from (66.218.6.104):
I bought this tractor last year, and while bush hogging it appeared to run out of fuel. The guage read 1/4 and I checked with a stick and sure enough, there was a good quarter of a tank left. I added fuel, bled the lines and filters, and it started right up and ran fine. I checked in the tank, and there's not a high riser tube that would prevent the last quarter tank of fuel from draining. Does this make sense to anybody? Is there something else I'm overlooking?
Post a Followup
: Re: 544 D fuel tank problem
