Farmall C Tractor Splitting
Posted by Rodney on April 13, 2004 at 14:04:17 from (66.82.9.62):
I have to replace the bearings in the top shaft in the transmission. I need to split the tractor between the torque tube and the transmission.
Do you have to disconnect the drive shaft from the clutch or will it slide out with the transmision when you split them. The only way I see to take the bolts out is small gap where the clutch rod goes and that might be a chore. Any help will be appreciated. Rodney
Post a Followup
: Re: Farmall C Tractor Splitting
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
