Re: Farmall C Tractor Splitting
Posted by gene b on April 13, 2004 at 19:35:13 from (67.1.104.215):
In Reply to: Farmall C Tractor Splitting posted by Rodney on April 13, 2004 at 14:04:17:
When you split it at the front of the tranny and move it 4in or so then you can disconnect the drive shaft at the u-joint. Those bolts are tapered and after the nuts are removed you can release the joint. I use a big piece of brass to bust the joint loose.
Post a Followup
: Re: Re: Farmall C Tractor Splitting
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
