Re: Re: Father-in-Law's 154 Low-Boy... Pease help.
Posted by Bama Binder on April 13, 2004 at 19:32:31 from (68.159.164.7):
In Reply to: Re: Father-in-Law's 154 Low-Boy... Pease help. posted by Esev on April 12, 2004 at 18:48:13:
Esev...have you checked the drive shaft to make sure it is straight? Other than that, I would check the engine mounts and rear axle and make sure no one started moving things around. Since the drive shaft is 4-5' long it wouldn't take much to put you off 1/2" if the engine had been removed and replaced 2-3 degrees off.
Post a Followup
: Re: Re: Re: Father-in-Law's 154 Low-Boy... Pease help.
