10-20 OR 15-30?
Posted by DAVE on April 14, 2004 at 03:57:33 from (69.40.233.162):
I have what I was told was a McCormick Deering 10-20 tractor. It does not have a serial number tag. The number stamped on the motor is KC341544. The casting code numbers on the engine and other parts have a "D" code. Can someone tell me if this is indeed a 10-20. It has the steering shaft offset to the right. I read this was done on the 15-30. It does not have a power takeoff shaft. I thought 10-20's came standard with this. Any help would be appreciated.
Post a Followup
: Re: 10-20 OR 15-30?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
