Re: Re: magneto timing trouble
Posted by Jeff on April 14, 2004 at 09:44:22 from (172.175.152.115):
In Reply to: Re: magneto timing trouble posted by Nebraska Cowman on April 14, 2004 at 04:24:43:
do you mean the impulse spring? the one in this mag needs to be replaced because you can barely feel or hear it snap. i took a good mag off of another tractor and thats when i found that the coulpling that attaches to the timing gear had play in it. i am just trying to make sure that this is something that will affect performance because its a lot of work to take that gear assembly out and put it back in. thanks for the help
jeff
Post a Followup
: Re: Re: Re: magneto timing trouble
