Re: the open - decal
Posted by Paul in Mich on April 14, 2004 at 19:41:20 from (68.188.227.110):
In Reply to: the open - decal posted by Bob G on April 14, 2004 at 10:52:14:
Bob, The "open" decal is used when the tractor is equiped with radiator shutters. From the shutters, there is linkage which goes back to the steering post. Those tractors with belly pump had a bracket with 2 holes which accomodated the crank control for the shutters. Some models however had the control crank on the 4x4 plate below the lift control bracket. In either case, the "open" decal was placed to the left side or directly above the shutter control crank. If your tractor does not have shutters, there is no need to put the decal anywhere. Decal sets come with all decals, but not all are needed on all models. You only use what applies to your particular tractor. I'm sure you realize you dont apply one to your forehead. If you don't realize that, then maybe you do after all...Ha.
Post a Followup
: Re: Re: the open - decal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
