Re: 1466 steering
Posted by Chuck's Repair on April 15, 2004 at 19:26:06 from (206.61.216.186):
In Reply to: 1466 steering posted by Joe on April 14, 2004 at 19:00:51:
If the rest of the hydraulic circuits operate correctly the pump is not the problem.The power steering has priority over everything else so it gets the first oil by way of an orfice.The rest of the oil is bypassed through a flow divider valve which might be stuck open which will lower your steering pressure from 2200 PSI to about 250 PSI.Check also to see if the piston seal in the steering cylinder is leaking.Another problem that causes hard steering is a dry bushing just below the steering wheel on tilt steering tractors.However the biggest problem on those tractors is not hydraulic but worn and dry bushings and thrust bearings in the front spindles.If the hydraulic system is building pressure in the steering system you can hear the steering relief valve squeal when you turn the steering wheel all the way to the stop and hold it there.I hope that helps you.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
