Re: Carburetor dozer blade questions
Posted by Randy in NE on April 16, 2004 at 04:32:59 from (216.58.237.20):
In Reply to: Carburetor dozer blade questions posted by Butch on April 15, 2004 at 13:42:26:
If you call your local Case/IH dealer and give them a good description of the body of the carb and where different set screws and fittings are located on it they can most likely identify it for you. Or just take it off and take it along. About the only way to put hydaulics on an A would be to put a pto hydaulic pump on it along with an oil tank. You are not going to have live hydraulics. Every time you set the clutch you will lose hydraulics. It would be workable but not convenient.
Post a Followup
: Re: Re: Carburetor dozer blade questions
