Grinding gears when shifting.
Posted by Kelly C on April 18, 2004 at 06:38:48 from (63.171.43.140):
What causes this on a 400? I have replaced the clutch/ TA and some transision gears. The clutch linkage is adjusted to the manual specs.
It grinds when shifting from R to 1st the worst. 2nd is not so bad.
I would assume that I still need some fine tuning of the clutch linkage. Because shouldnt the transmision gears not be turning at all when you ingage the clutch? I do have some play in the clutch pedal. It slops from side to side so maybe I need to have a little more push in the pedal to compessate. Just wondering what you guys have done.
Post a Followup
: Re: Grinding gears when shifting.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
