Re: Farmall B Exaust lift
Posted by gene b on April 19, 2004 at 02:47:48 from (67.1.98.35):
In Reply to: Farmall B Exaust lift posted by donwisc on April 18, 2004 at 20:03:18:
There is more than just the big cycl to make it work. How good is the rest of the system is it all there? When you pull the lever back it should raise the piston. The return is brought down by the wt of the cult. If the cycl is on the left side where the lite is that is the position for the cult. The cycl bolts to different places for other implements. You can also check out the cycl by using air pressure from compressor. I have four systems working and some parts.
Post a Followup
: Re: Re: Farmall B Exaust lift
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
