Re: Farmall A won't start
Posted by Bigdog on April 20, 2004 at 15:11:35 from (12.162.180.121):
In Reply to: Farmall A won't start posted by Bigdog on April 20, 2004 at 10:17:39:
have good spark but the plugs are dry but i know it is getin gas to the carb. checked the timing is timed right, good spark, gas to carb, good compression, should run but it don't
Post a Followup
: Re: Re: Farmall A won't start
