Re: Re: Farmall A won't start
Posted by (The other) Bigdog on April 20, 2004 at 16:55:13 from (204.210.231.110):
In Reply to: Re: Farmall A won't start posted by Bigdog on April 20, 2004 at 15:11:35:
When it got hot you may have warped the head or manifold. If you have gas to the carb, it sounds like it's not getting to the cylinders. You might try dribbling a little gas in each cylinder, replacing the plugs and see if you get any firing at all.
Post a Followup
: Re: Re: Re: Farmall A won't start
