Re: Farmall H Low oil pressure
Posted by Mike ISW on April 20, 2004 at 15:45:45 from (152.163.252.227):
In Reply to: Farmall H Low oil pressure posted by Mark in Mi on April 20, 2004 at 05:21:22:
First of all you need to find out if your oil pressure gauge is reading correctly. This is done by disconnecting present gauge and installing another (known good) oil pressure gauge/hose assembly. Then work tractor as normal and get cold and hot readings and compare with readings you mentioned. Th oil pump on a "H" a piece of cake to change out. Albiet messy and you tend to get dripped on alot. A few things to look for are as follows: gear backlash and cover clearance to gears. There is a VERY thin gasket on that cover. You should also clean pick-up screen and check for obstructions in pick-up tube. You will also need to check relief valve spring and ball. I do not recommend but have heard of guys stretching this spring slightly for a bit more pressure. Again I have not tried that and do not recommend. From there you need to check rods,mains and cam bearing clearances. HTH, Mike Let us know how you come out.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
