Re: 1949 M with disk brakes....
Posted by Haas on April 22, 2004 at 04:41:13 from (12.65.18.104):
In Reply to: 1949 M with disk brakes.... posted by jamie on April 21, 2004 at 18:22:30:
Find a clutch/brake shop that does relining work. They can reline the Lambert Disks for you. The lambert disks have a different spline on them than the Super series disks. The Super series disks are flat with a narrow spline. The splines on the Lambert disks have an extended sleeve. When I redid mine, the IH dealer could still get the new disks for the Lamberts, but much more expensive than having them relined. After relining, the brakes work great. I needed a return spring that is internally mounted. Had a hard time finding that, as IH could not get. Also, the info about the mounting bolts provided by others here is correct. Three mounting bolts on the Lambert brakes.
Post a Followup
: Re: Re: 1949 M with disk brakes....
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
