Re: HEY CHADS, about your 460 puller
Posted by ChadS on April 22, 2004 at 06:23:18 from (66.228.96.223):
In Reply to: HEY CHADS, about your 460 puller posted by Fred on April 21, 2004 at 15:47:57:
Not a problem! In fact, here is what I did. Basicly, you can unbolt a 460, from the rear engine plate, forward, and bolt it into a H rear end. all the frame rails, and engine plate are the same bell housing bolt pattern as the H. all the factory engine mounts from the 460 fit the combine engines, (front) it is a bolt in task!! OK, here is what you have to do for the clutch,, use the 460 flywheel, 460 pressure plate, and a Super H 10.5 clutch disk. The H and Super H, have the same spline on the input shaft, just a larger diameter clutch. and is available in a 3,4 or 6 pad button clutch. OK now the hard part, the starter ring. the 300-350-460 had the same starter ring, and was used for the new style starters, on the H, you have the old style starter, you have to remove the 460 starter ring, machine the flywheel down in the lathe, to fit the H starter ring to the 460 flywheel. it sounds more difficult than it actually is, it took me about 1/2 hr to cut it and fit it. after that, you can use the original starter from the H. You need to use the H pilot bearing in the flywheel, it goes right in! I have a spare 460 flywheel set up for an H starter ring if you want it, All IH parts is used in this conversion! Other than the machine work on the starter ring, it is a direct bolt in as far as the bellhousing, frame rails, front end, etc etc. I could save you all the hassle too, you can buy mine! Anyways, hope this helps, email me if you like at hpuller2001@yahoo.com thanks, Chad
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
