Re: Lift jerky on IH454
Posted by Haas on April 22, 2004 at 18:19:17 from (12.65.42.119):
In Reply to: Lift jerky on IH454 posted by shockley on April 22, 2004 at 17:42:44:
The jerky lift is likely a faulty seal in the cylinder. Also could be the control valve. If there is a shut off valve (I know the 424 has one) that will hold the lift, raise the lift with a load on it and then shut off the valve. If the lift goes down, then the cylinder seal is bad and needs to be replace. You may also have to replace the piston.
Post a Followup
: Re: Re: Lift jerky on IH454
