Re: 49 M backfiring?
Posted by Bob M on April 24, 2004 at 06:26:31 from (66.67.15.60):
In Reply to: 49 M backfiring? posted by jamie ivester on April 23, 2004 at 21:32:46:
Jamie - An occasional light pop out the exhaust at idle is normal. You can try enriching the idle mixture a bit (turn the idle mix screw IN) and see if this helps. Wouldn't hurt also to check the timing - also that the centrifugal spark advance is working (advances the timing as the engine speeds up...)
But if the engine runs good otherwise I wouldn't worry about it.
Post a Followup
: Re: Re: 49 M backfiring?
