Re: Tinkering with my 400
Posted by Wardner on April 24, 2004 at 12:55:58 from (4.138.240.7):
In Reply to: Tinkering with my 400 posted by Kelly C on April 24, 2004 at 12:00:19:
Good luck with the bracket. It looks like you got the right cylinder anyway. Even with the stock bracket, you will find that the cylinder will stall under full pressure sometimes. This is why I would only use the IH mfg-ed item.
I suggest that you put right angle adaptors on the ports. With your bracket you could even rotate the cylinder 180* so that the ports are tucked inside.
The new cylinder and bracket will make a big difference with the bale spear. You should get an additional 8-12" lift at the point plus fork-lift type tilt.
Post a Followup
: Re: Re: Tinkering with my 400
