Re: Farmall M wort crank over
Posted by FH on April 24, 2004 at 18:02:45 from (68.135.141.204):
In Reply to: Farmall M wort crank over posted by Pete T on April 24, 2004 at 17:02:34:
Usually when a cable/clamp gets hot, there is a bad connection or a short. Be sure the engine is not locked up and not in gear. Check and clean 'each' connection from battery to switch to starter, and the ground. I have pulled a starter and it spun on the bench but still couldn't turn the engine, when means it needed a rebuild. Your flywheel could be boogered up causing the bendix to bind or stick, also.
Post a Followup
: Re: Re: Farmall M wort crank over
