Farmall M wort crank over
Posted by Pete T on April 24, 2004 at 17:02:34 from (69.21.0.105):
I have a Farmall M that the starter will not turn over all even if jumped from the battery.
I took the starter out and replaced it, I also checked the starter when it was out of the tractor
and the start works on the bench.
When you tuch the starter bolt with a jumper cable you can here it click but it will not crank the engine.
And the Jumper Cable gets pretty hot.
Any ideas of what I could check.
Thanks
Pete
Post a Followup
: Re: Farmall M wort crank over
