Re: Farmall Cub will not run
Posted by LITTLE RED on April 25, 2004 at 09:23:20 from (209.94.180.45):
In Reply to: Farmall Cub will not run posted by Jerry Premack on April 25, 2004 at 08:55:17:
JP
YOU MENTIONED THE CUB WILL RUN ON FULL CHOKE
THIS LEADS ME TO BELIEVE YOUR PROBLEM IS FUEL RELATED EITHER AT THE FUEL TANK OR AT CARB THE FIRST THING I WOULD DO IS PULL THE FUEL LINE OFF AT THE CARB CHECK TO SEE HOW MUCH FUEL IS FLOWING IT SHOULD HAVE AGOOD STREAM COMING OUT IF THATS GOOD THE NEXT THING I WOULD CHECK IS THE CARB FILTER SCREEN WHERE THE FUEL LINE CONNECTS TO THE CARB IF THATS CLEAN I WOULD
SAY YOU CAN LOOK AT THE CARB AS YOUR PROBLEM GOOD LUCK LITTLE RED
Post a Followup
: Re: Re: Farmall Cub will not run
