Re: Farmall Cub will not run
Posted by George Willer on April 25, 2004 at 09:56:09 from (208.252.179.24):
In Reply to: Farmall Cub will not run posted by Jerry Premack on April 25, 2004 at 08:55:17:
Check for good, sustained fuel flow by removing the 1/8" pipe plug on the bottom of the carburetor bowl. If the flow remains strong after a cupful or so flows, check the main jet. It's the hex head on the bottom of the left side. The small metering hole in the tip may be partially or completely plugged.
George Willer
Post a Followup
: Re: Re: Farmall Cub will not run
