Re: Farmall M wort crank over
Posted by Gunhunter21 on April 25, 2004 at 17:01:22 from (24.154.52.17):
In Reply to: Farmall M wort crank over posted by Pete T on April 24, 2004 at 17:02:34:
Make sure your ground to the tractor from the battery is really good. Put jumper cable on starter housing and the other end on battery ground terminal, then try starting tractor. This is the best ground you can get. Just had the same problem with my truck. A little cleaning of connections solved the problem.
Post a Followup
: Re: Re: Farmall M wort crank over
