Re: Farmall Cub will not run
Posted by Bigdog on April 25, 2004 at 17:41:05 from (24.160.187.128):
In Reply to: Farmall Cub will not run posted by Jerry Premack on April 25, 2004 at 08:55:17:
You might be pulling in excess air through a leaky carb flange / manifold gasket or perhaps a leaky manifold gasket. You can check by using an unlit propane torch. Just open the valve on the torch and move it around the mating surfaces. If it smoothes out and will run with the choke in, you've found your leak. Be very careful doing this.
Post a Followup
: Re: Re: Farmall Cub will not run
