Re: Re: Re: Re: Re: Lift or draft control symptom
Posted by Hugh MacKay on April 27, 2004 at 03:33:39 from (216.208.58.190):
In Reply to: Re: Re: Re: Re: Lift or draft control symptoms? posted by Mac on April 26, 2004 at 17:36:53:
Mac: Correct me if I'm wrong, but as I see this when you are doing other work, like loader work or just plain driving from point A to point B the hitch will settle a couple of inches then all of a sudden lurch to max height? Will it do the same if nothing is hitched to 3 point, and you have a situation whereby it is just the weight of hitch itself? On your draft control OFF will be in the far light end of range. If you had an original IH operators manual, you would find it much better on operating topics. IT manuals I find are more geared to repair and rebuild. My first opinion is the tractors internal lift cylinder is bypassing. I base this on the fact the hitch will go down in 2 hours if you leave it parked with disk up. I am also not sure this related to the lurching of hitch. The lift cylinder is the expensive fix, I like to look at the easy, non expensive items first. What happens if you leave the hitch down a couple of inches? I have seen the frame around lever get bent just a bit, thus allowing the operator to move the lift lever just a bit beyond its normal limit. Draft control if not working right can do some funny things also. Is this tractor upper or lower link sencing for the draft control. Most draft control problems are something bent or stuck. I presume you have tried every concieveable position for the levers. Does the rate on this hitch lurching change if tractor is running at low idle, then compared with say 1200 rpm? I'm thinking bypassing in lift cylinder should remain constant,(length of time it takes to settle the 2", I realize the upward lurch will be faster with rpm) whereas draft control problems will change with rpm change. While I say this it may not resolve anything. I do realize how annoying this can be, been there and done that. I've always been lucky in that it was something bent or out of adjustment. A couple hours observing will be a whole lot cheaper than tearing into that lift cylinder.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
