Re: Re: Re: Re: Re: Re: Lift or draft control sym
Posted by Mac on April 27, 2004 at 10:05:47 from (217.144.243.200):
In Reply to: Re: Re: Re: Re: Re: Lift or draft control symptom posted by Hugh MacKay on April 27, 2004 at 03:33:39:
Yep Hugh jerking follows rpms and I don't think it's present without disc or at any other position except max lift. The draft sensing is relayed through top link mount via a sensing rod and torsion bell crank. I could live with the jerking, but the inability to maintain max lift is insufferable. *Is it normal for position lever to follow lift drop with cyl leakby, or does it sound like a lever friction adjustment on control?* I'll surely try all adjusting before pulling lift housing.
I'm at work in Brazil and will follow up when I get back. I'm so busy using it when home,I rarely have time for computer or tractor tinkering, so I try to sort this stuff out from memory with you gurus while offshore.
Mac
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Lift or draft control sym
