Re: M Lambert brake tear down results
Posted by Haas Incorrect info, Sorr on April 27, 2004 at 05:21:27 from (12.65.19.225):
In Reply to: M Lambert brake tear down results posted by jamie on April 26, 2004 at 20:10:49:
I should have looked at my parts info before posting below. There is a hub that goes over the pinion shaft that has the splines for the disks. Don't know if that is available as a new part or not. However, if you got it from IH, I'm sure it would be very expensive. I'd try salvage dealers like Steel Wheel Ranch, or JP tractor salvage. Also, I forgot to mention that my IH dealer told me he could not get the cone shaped return springs. I ran my brakes for some time without the spring on one side. The brakes worked without it and I really could not tell much difference after I put in the used spring I found. If you need any part numbers, post back, and I will look them up for you.
Post a Followup
: Re: Re: M Lambert brake tear down results
