Farmall Tractors Discussion Board
Re: Question on a Farmall A
Posted by D Smoker on October 25, 1999 at 17:07:14 from (208.170.184.84):
In Reply to: Question on a Farmall A posted by Jered Kindsfater on October 25, 1999 at 00:19:06:
According to the original manual I have the "A" could be had with a distillate engine. You start the engine on gasoline and then when it warms up you switch it to kerosene. The small tank would be the kerosene tank. The compression ratio would also be lower on the distillate engine. You can run it on gas all the time but it won't make as much power as the regular "A" unless you change the pistons. As to the hydraulic pump sounds like somebody removed the Touch Control and subsituted a homemade setup. Don't know about the seat. In eastern PA a decent "A" goes for about $1200.00
Post a Followup
: Re: Re: Question on a Farmall A
