Re: stupid, where is the coil?
Posted by John *.?-!.* cub owner on April 27, 2004 at 21:19:51 from (66.112.34.4):
In Reply to: stupid, where is the coil? posted by farmallsc on April 27, 2004 at 16:16:37:
If it by chance has a WICO magneto on it, the coil is inside. On this type there is no center post on the distributor cap, only the 4 posts going to the spark plugs.
Post a Followup
: Re: Re: stupid, where is the coil?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
