International A Not Running
Posted by Larry Hardesty on April 28, 2004 at 07:58:43 from (198.151.180.56):
Every since I started using my International A this spring it has not ran well. It is stored inside and I start it every couple of months during the winter but do not use it. It has a belly mower on it to use for mower. First, I had trouble starting it. Then I cleaned the sediment bulb (some rust in it) and the gas line. The blew out the carb with some carb cleaner. Seemed to run fine. This past weekend I started mowing with it again. It seemed to be missing, and eventually to died. I again took the gas line off and the sediment bulb. I did not see any dirt. I also took off the carb and blew it out again. Still did not run right. Gave up and and I took the carb into the local Case-IH dealer and had them soak the carb well and put in a new kit. The mechanic who worked on it said he did not see anything wrong in the carb. I put on the carb last night. Tractor was hard to start, would run for awhile, surge and act like not getting gas and then would die. In a few minutes it would start again and then miss and die. Gas does get to the carb, and the carb is supposedly clean. Any ideas. Would water in the gas do this? Would water show up in the sediment bulb (I have not seen any)? Previous owner had converted it to 12 volt alternator. Would a bad coil or condenser make it at this way? If so, how to do I check them? Open to suggestions and thanks in advance. A 2nd question, is a special spark plug wrench needed to remove the spark plugs? My sockets seem to think to get into the recess to get on the spark plugs.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
