Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Engine knock F-20
Posted by TMAC on October 25, 1999 at 19:39:24 from (207.144.168.221):
In Reply to: Re: Re: Re: Re: Engine knock F-20 posted by Randy on October 25, 1999 at 16:53:46:
Your F20 has shims for adjusting the bearing. You will have to remove one or more equally from both sides of the rod. There will be thin shims sandwiched between two thick shims. The thin shims are the ones you will remove. You don't have to remove the bolts, just loosen them and pull at the shims. They don't fully surround the bolts and will come out. Try one pair at a time and then tighten the bolts and check for fit. I have done this with my F30.
Post a Followup
: Re: Re: Re: Re: Re: Re: Engine knock F-20
