Re: Re: Re: Re: Re: Re: Engine knock F-20
Posted by George Mikesell on September 07, 2004 at 13:34:17 from (209.42.79.239):
In Reply to: Re: Re: Re: Re: Re: Engine knock F-20 posted by TMAC on October 25, 1999 at 19:39:24:
I have been studying what you have said about the knock on the f-20. First of all the back and forth movement of rod on crank is normal, it is built in. You need to make sure of crant to rod bearing clearance. This would be vertical movement. You really need to check this clearance at top of stroke and then half way down or when the through you are working on is horizontal. This for checking flatness of crank. Or better yet would be to mike the shaft. Yes this can be done fron inspection hole. That was the idea of inspection hole, you can remove the piston and put in rings this way, not easy but can be done. If the rod is truly loose I would want to know why it did not get oil. Pan is not hard to remove I would pull it and see if the oil line is pointing at the dipper. Or if it has came loose and not oiling the rod at all. Also the dipper may be messed up or have something in it thus keeping rod from being oiled. My best advice at this point is check evgerything from oil pump to oil distribution and dipper. Ps clean oil pan and run water through the main tube check for leaks and where waater shoots out will give you good idea if oiler is pointed ad dipper. You can adjust rod bearing by taking out shims, three and one half thousands to five is good fit. Use plasti guage to check can be gotten at local parts store. Remember Check and find out why the problem has occurred.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
