Re: Re: Re: F-20 clutch houseing removel
Posted by F20 in Mi on April 29, 2004 at 08:20:52 from (68.249.242.162):
In Reply to: Re: Re: F-20 clutch houseing removel posted by John in NE on April 28, 2004 at 22:52:00:
To reinstall the flywheel, pull our your charcoal grill and let the flywheel heat for about a half hour. Screw a couple of bolts into the flywheel to make handling easier. Put the sleeve in the freezer overnight. You need one guys for the sleeve and two for the flywheel. No beating required. Just slide everything together. Believe me it worked great and we didn't have to worry about damage to the crank etc. Also suggest you replace the throw out beating while you are there.
Post a Followup
: Re: Re: Re: Re: F-20 clutch houseing removel
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
