Re: Re: 656 oil problem
Posted by Hurley J. D. on April 30, 2004 at 09:50:58 from (67.128.178.140):
In Reply to: Re: 656 oil problem posted by Jim J on April 29, 2004 at 23:20:09:
How can I determine if the head gasket is not correctly installed without removing the head. Can I look through the oil passage holes in the head with a flash light and determine this. Thanks
Post a Followup
: Re: Re: Re: 656 oil problem
