Re: 656 oil problem
Posted by Jim J on April 29, 2004 at 23:20:09 from (65.222.50.166):
In Reply to: 656 oil problem posted by Hurley J. D. on April 29, 2004 at 14:19:15:
I have seen this problem several times. The valve train don't get any oil because the head gasket
was installed up side down blocking off the oil passage to the head.
Post a Followup
: Re: Re: 656 oil problem
