Re: M wide front
Posted by Paul in Mich on April 30, 2004 at 19:20:05 from (68.188.227.110):
In Reply to: M wide front posted by Bruce W on April 30, 2004 at 12:58:38:
Bruce, #1 Front mounted steering linkage is probably correct for your M unless you have an SM. #2 If your wheel hubs have a lip on the inside, it takes the rims with no loops, and you need lugs and bolts to hold them in place. If your wheel hubs have no lip, then you need the looped rims that require bolts but not lugs themselves. #3 The Axle tube clamp should be available at steelwheel ranch, or several other used part sources. #4 YOu should have no trouble installing the WFE if the reciever plate is correct. The H and M used the wame WFE, but different reciever plates. Other than that, good luck.
Post a Followup
: Re: Re: M wide front
