Farmall A rear axle housing
Posted by Mike on May 01, 2004 at 11:30:26 from (67.234.4.12):
I recently pulled the left rear axle housing pan off to change the oil, and found in the bottom of the pan, what was left of the rear axle inner bearing washer. I need to replace it and I'm wondering if this will be a major job or easy fix.
I'm new to tractors and need a little guidance.
I really appreciate the response from the Farmall
enthusiasts on the internet with some of my questions in the past, so I hope someone can help me again, thanks
Post a Followup
: Re: Farmall A rear axle housing
