Re: Stripped threads in final drive housing
Posted by Kent on May 02, 2004 at 18:15:19 from (12.214.34.211):
In Reply to: Stripped threads in final drive housing posted by Darren in TN on May 02, 2004 at 16:42:50:
Darren, I am unsure what a buddy of mine uses but they are far superior to a helicoil. I thought helicoil was the greatest until I just saw these the other day. What you have to do is drill out the hole to the specified size and retap the hole to fit this insert that is the same bolt size you had before. Put your old bolt in it with a jam nut to tighten in the insert. Once it is in place you take a drift punch and a hammer and drive in 4 small stakes that are made on the insert. My buddy showed me several different jobs he has used them and they all are doing well. The only drawback I can see is if you don't have enough room or the cost of them. He has boxes of all different sizes and said the one he was using was @$6.00 each for @7/16 inside and 1/2 outside. They are similar to these at WWW.ezlock.com Good Luck, Kent
Post a Followup
: Re: Re: Stripped threads in final drive housing
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
