Re: 57 SMTA
Posted by randy hall on May 03, 2004 at 20:41:56 from (209.11.236.52):
In Reply to: 57 SMTA posted by DON C on May 03, 2004 at 17:14:29:
the bore in the block is the same size on a 264 or a 281 block. i doubt if there are are any super m's out there that have not had the thinner sleeves and larger pistons installed.
Post a Followup
: Re: Re: 57 SMTA
