Re: Re: SUPER M SLEEVE REMOVABLE
Posted by Jonathan Mirgon on May 04, 2004 at 03:16:36 from (205.208.129.34):
In Reply to: Re: SUPER M SLEEVE REMOVABLE posted by Eric W on May 03, 2004 at 21:14:12:
You will have to obtain or make a sleeve puller, get a piece of solid 7/8" steel and have it turned round on a lathe the same diameter as the bottom of the sleeve, drill a hole in the puck and then use a piece of heavy duty all thread, and use a nut on the top and a bridge. tightening the nut on the top will pull the liner out. Use a cylinder hone in the bore after all of the sleeves are out to clean them up. then freeze the new liners over night and they will go back in pretty easy.
Post a Followup
: Re: Re: Re: SUPER M SLEEVE REMOVABLE
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
