Re: more on hard starting 1066
Posted by Hugh MacKay on May 07, 2004 at 02:04:20 from (216.208.58.151):
In Reply to: more on hard starting 1066 posted by Tom on May 06, 2004 at 22:38:15:
Tom: Sounds as though the fuel injection system is taking in air. You must have a leak somewhere in system. It could be anywhere between fuel tank and injection pump or even within the pump. If the tractor is working well when running, then air must enter during time engine not running. Or you have a leak that could get a whole lot worse. Look for cracked lines, cracked filter base, bad seal on filter. Had a Cat once performance was terrible, after some looking we discovered gasket behind inspection plate for timing was leaking. Not enough to allow fuel out but did let air in.
Post a Followup
: Re: Re: more on hard starting 1066
