Re: cub carb headaches
Posted by Farmer Bob on May 07, 2004 at 07:50:54 from (64.113.14.197):
In Reply to: cub carb headaches posted by Pete on May 07, 2004 at 00:31:47:
Pete, Awhile back I captured this from an Article in Red Power Magazine...hope it helps!
Hi I'm TEC.
One of the tips I'll give out this month is related to the needle valve and seat on the Farmall Cub tractor with the IH made carb. The needle/seat assembly from IH (#251300R21 ) sometimes sticks causing the carb to flood out. The solution is to replace the needle valve with one from an
IH Cub Cadet. I recommend you use Kohler Engines part # KH-25-757-01 carb kit to do this. The gaskets in the Kohler kit are useless here, you only need the needle valve. Priced at about $8 the Kohler kit is a bargain fix for a messy problem.
Post a Followup
: Re: Re: cub carb headaches
