Re: 560 LP Head
Posted by Heat Houser on May 07, 2004 at 21:41:51 from (69.66.106.177):
In Reply to: 560 LP Head posted by Ohio M Puller on May 07, 2004 at 05:52:09:
LP heads had Stellite exhaust seats and Stellite valves. These would take the abuse better since LP did not have any lead in it. An LP head will work fine on a gasser since the difference in compression, higher on the LP, was done by a raised step on the top of the piston. As I recall, the gasser piston was flat not stepped like the LP. I am running LP pistons in my 560 gasser to bump up the compression. It tends to diesel when shutting down hot.
Post a Followup
: Re: Re: 560 LP Head
