Farmall Tractors Discussion Board
Re: Charlynn pump on pto has leaking seal.
Posted by GeezerMn on October 26, 1999 at 17:24:55 from (216.161.105.10):
In Reply to: Charlynn pump on pto has leaking seal. posted by Rod Hergott on October 25, 1999 at 19:19:09:
If you have the round style pump that contains the reservoir & valves, the seal may be removed
without disassemby.---If you are careful.Do not
damage shaft or housing. Measure I.D.& O.D.of
seal NAPA or other parts place can match it.Use
a slidehammer puller with a screw end to pull it.
The Charlyn seal # is 15401 This is a model 600
HI-lo-PAC. Could be 45 years old.
Post a Followup
: Re: Re: Charlynn pump on pto has leaking seal.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
