Re: H vs JD 70 D plowing
Posted by gene b on May 09, 2004 at 02:49:04 from (67.1.105.228):
In Reply to: H vs JD 70 D plowing posted by riverbend on May 08, 2004 at 20:11:10:
Like the other post says if you want to play with a 70 get an M. Would also make some sense if you each had same plows. Comparing 2-16 to 3-14 never will make sense.
Post a Followup
: Re: Re: H vs JD 70 D plowing
