Re: H vs JD 70 D plowing
Posted by Phil Munson on May 09, 2004 at 07:01:55 from (66.218.22.186):
In Reply to: H vs JD 70 D plowing posted by riverbend on May 08, 2004 at 20:11:10:
If the tractor is running well don't mess with it. What plow are you pulling? If it is a P&O what do you expect? It seems like it takes about twice the power to go from 2nd to third with them. An easier pulling plow, like and oliver, or an IHC with the Hi speed bottom would be an easier and probably cheaper way to get into third gear.
BTW, the H was rated for two plows and the 70 for four.
Post a Followup
: Re: Re: H vs JD 70 D plowing
